I am replacing both the Left and Right CV Half Axles in my Rodeo 4WD (DOHC Engine). I have eveything apart down to unbolting the fronty axle assemble from the body (front wheel bearings removed, cv half axle to front axle assembly flanges unbloted , drive shaft unbolted from the front axle assembly, etc.). However, I do not see how I can get enough play between the left half axle, front axle assembly and right half axle to seperate either half axle inner spindle from the front axle assembly, or outside spindles from the hubs. Are there any tricks?
Aug 4, 2008 at 9:56 AM
