Engine Performance problem
1998 Isuzu Rodeo Question 4 cyl Two Wheel Drive Manual
Head gasket blew between 3 & 4 cylinder. Had the head reconditioned and installed everything to specifications. Now the engine is missing on cylinders 3 & 4. The timing is set perfectly to spec, there is 155 psi on each cylinder, both cylinders are getting fire and both injectors are operating. When I removed the plugs they had a carbon/fuel foul look to them. Also, there is no check engine light. What is your thoughts?
Feb 10, 2010 at 6:36 PM
