this car is used only when my kids come home from colledge so it sits for 4 months at a time last time it ran ok the ac compessor seized that was repaired and as i took car for test drive the engine started missing badly went back home and did tune up same problem did compression test all cyl. 130 psi except #6 218 psi assumed exaust valve not oppening so pulled valve cover cam lobes seem fine lifters go up and down im at a lost could the exaust manifold be plugged? help thanks curt
May 8, 2009 at 12:18 AM
