1996 Isuzu Rodeo Question Scan Code of P0420
1996 ISUZU RODEO
160,000 MILES • 4 CYL • 2WD • MANUAL
SENTARI
Hey...
I have OBDII scan code of P0420 and I looked it up and has to deal with a low Bank 1 Cat Conveter.
What does this mean? Do you think its a Cat Coverter or an Oxy Sensor.
I would drive about 6 miles after I reset the light and it come back to P0420 each time.
Thanks for your time!
Larry Files
Jun 6, 2008 at 9:28 AM
DOCHAGERTY
  • 9,603 POSTS
The fault code is set due to the catalytic converters inability to properly perform its function. At 160k miles it needs to be proven to be faulty and condemned properly.
Jun 7, 2008 at 9:44 AM
SENTARI
Thanks Dr Hagertry for a quick response and it turned out the catalytic converter was an OBD I type and I'm betting it was installed as a cheap and quick fix before the I bought it at an auction two years ago.
I replaced it with an aftermarket OBD II catalytic converter and my high NOX and the Check Engine light are gone.
Jun 7, 2008 at 12:49 PM
DOCHAGERTY
  • 9,603 POSTS
Thank you
Jun 7, 2008 at 2:29 PM
