Engine Cooling problem
1996 Isuzu Rodeo Question 6 cyl Automatic 200 miles
My question is this, the truck sat for some time and after a tune up it over heated. It sat for about a month then we made sure it had water in it then took it for a drive. Temp got warm so we replaced the thermostat. 3 days later it over heated again with lots of smoke and it died. Mechanic checked and it had 2 leaks from 2 hoses that were then replaced along with flushed out radiator, new water and antifreeze and oil change. With ac running cold, temp gets almost to hot only when running on expressway. When I slow down or take foot of gas or come to a stop, temp goes down. Not to normal temp but a little more warm. At that time you can smell antifreeze but there is never any smoke. Try to turn on heater but there is no hot air. Another mechanic looked at it and said it could possibly be the radiator. What do you suggest. I do not have alot of cash to take it somewhere for a diagnostic. The cheaper the fix the better!!
Aug 2, 2010 at 6:03 PM
