1996 Isuzu Rodeo Question High Idle Speed
1996 ISUZU RODEO
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
PHILZALE
I've got a schizophrenic 96 Rodeo, 3.2L, 135K miles that about 2 years ago developed a high idle speed of about 2100/2200 rpm.
Replaced TPS (Throttle Position Sensor) and that seemed to fix the problem for about the last year when it began happening again.
Replaced ICV (Idle Control Valve) a couple of weeks ago and that too seemed to fix the problem. Unfortunately it's begun to happen again.
It's very intermittent. I cannot come up with any type of regular scenario under which it occurs.
Looking for advice as to where to look next.
Thanks!
Aug 25, 2010 at 12:05 PM
KHLOW2008
  • 41,814 POSTS
Hi philzale,
Look for possible vacumn leakages. If IAC has coolant hoses attached to it, check the coolant hoses for clogging and coolant level in radiator.
Aug 30, 2010 at 12:40 PM
