1995 Isuzu Rodeo Question White smoke from exhaust
1995 ISUZU RODEO
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
LCARPANZANO
Just got new radiator - mechanic didn't tighten hose and car overheated on way home. Mechanic fixed hose, but now when I start the car in the a.m. white smoke comes from the exhaust. I think head gasket or leaks are present from overheating - does this make sense and if so, should I contact mechanic to fix problem since it is probably a result of his work.
Thanks,
LBC
Jul 24, 2008 at 2:11 PM
If its not condensation-get it block and pressure tested this will lead you into something
Jul 24, 2008 at 2:18 PM
