1995 Isuzu Rodeo Question problems with the clutch
1995 ISUZU RODEO
NUNU0411
my clutch on my 95 rodeo goes all the way down and the gear wont go into shift does anyone have any idea what is wrong with it??? please help....
Jan 20, 2008 at 2:55 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Check the reservoir for fluid.
If low or empty you will have a leak at the master cylinder or the slave cylinder. replace faulty components and bleed system. If you are not able to do this your self, add fluid (brake fluid) and try clutch, you may have enough clutch response to get to a mechanic. Try this first.
Mark (mhpautos)
Apr 5, 2021 at 2:19 PM
