1995 Isuzu Rodeo Question harmonic balancer
1995 ISUZU RODEO
152,742 MILES • 6 CYL • 2WD • AUTOMATIC
RAMPAIGEOUS
The Harmonic Balancer on my 95 Isuzu Rodeo broke and now the belt is not working. The truck still starts up and drives but the A/C stopped working. Is it okay to drive the truck or will I damge the engine? What funtions does the Harmonic Balancer operate on the vehicle?
Dec 29, 2008 at 9:46 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This is a critical component and should be replaced, see text for an explanation as to the function of the harmonic balancer.
Mark (mhpautos)
A harmonic balancer (also called crank pulley damper, crankshaft damper, torsional damper, or vibration damper) is a device connected to the crankshaft of an engine to reduce torsional vibration.
Every time the cylinders fire, torque is imparted to the crankshaft. The crankshaft deflects under this torque, which sets up vibrations when the torque is released. At certain engine speeds the torques imparted by the cylinders are in synch with the vibrations in the crankshaft, which results in a phenomenon called resonance. This resonance causes stress beyond what the crankshaft can withstand, resulting in crankshaft failure.
To prevent this vibration, a harmonic balancer is attached to the front part of the crankshaft. The damper is composed of two elements: a mass and an energy dissipating element. The mass resists the acceleration of the vibration and the energy dissipating (rubber/clutch/fluid) element absorbs the vibrations.
Over time, the energy dissipating (rubber/clutch/fluid) element can deteriorate from age, heat, cold, or exposure to oil or chemicals. Unless rebuilt or replaced, this can cause the crankshaft to develop cracks, resulting in crankshaft failure.
Dec 29, 2008 at 10:18 PM
