1995 Isuzu Rodeo Question FLASHER REPLACEMENT
1995 ISUZU RODEO
DPHILLIPSRVT
Electrical problem
1995 Isuzu Rodeo Question 6 cyl
NEED REPLACEMENT INSTRUCTIONS ON HOW TO REPLACE FLASHER
Oct 24, 2010 at 4:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
it is located directly behind the front driver-side speaker. remove the lower dash facing in front of the speaker (I believe there are two screws at the bottom and the top hinges up and off), remove the four screws holding the speaker in place, and then you should see the relay
Oct 24, 2010 at 5:51 PM
