Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Isuzu
Rodeo
Climate Control
Blower Fan
Resistor
1995 Isuzu Rodeo Question Blower motor
1995 ISUZU RODEO
117,000 MILES • 6 CYL • 4WD • MANUAL
SCOTTRODEO
MEMBER
FOLLOW
The blower motor does not work at any speed. The fuse is good, the new blower motor did not work either. Any suggestions besides the resistor?
Jul 31, 2009 at 12:07 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
test switch to ensure it is sending signal to the motor. if not then switch is bad, if it is then resistor is at fault
Jul 31, 2009 at 12:19 PM
SCOTTRODEO
MEMBER
Thank you for the fast reply! I will investigate the switch. I guess diagrams would be helpful now. Thanks!
Scott
Jul 31, 2009 at 12:38 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
see if this helps..
Jul 31, 2009 at 12:43 PM
NATHAN08T
MEMBER
It's REALLY hard to see that picture you posted.. =(
How much is a new blower motor? I need one for mine also..
Aug 8, 2009 at 10:25 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
you can purchase a new blower motor for your vehicle for around $75 at www.AutoZone.com
Aug 8, 2009 at 10:41 AM
NATHAN08T
MEMBER
Do you know where the blower is located at? I heard it's behind the glove compartment.
Aug 8, 2009 at 3:44 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
blower motor is located below the right side of dash, under glove compartment area.
Aug 10, 2009 at 9:49 PM
