1995 Isuzu Rodeo Question Blower motor
1995 ISUZU RODEO
117,000 MILES • 6 CYL • 4WD • MANUAL
SCOTTRODEO
The blower motor does not work at any speed. The fuse is good, the new blower motor did not work either. Any suggestions besides the resistor?
Jul 31, 2009 at 12:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
test switch to ensure it is sending signal to the motor. if not then switch is bad, if it is then resistor is at fault
Jul 31, 2009 at 12:19 PM
SCOTTRODEO
Thank you for the fast reply! I will investigate the switch. I guess diagrams would be helpful now. Thanks!
Scott
Jul 31, 2009 at 12:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
see if this helps..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_767.jpg
Jul 31, 2009 at 12:43 PM
NATHAN08T
  • 14 POSTS
It's REALLY hard to see that picture you posted.. =(
How much is a new blower motor? I need one for mine also..
Aug 8, 2009 at 10:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you can purchase a new blower motor for your vehicle for around $75 at www.AutoZone.com
Aug 8, 2009 at 10:41 AM
NATHAN08T
  • 14 POSTS
Do you know where the blower is located at? I heard it's behind the glove compartment.
Aug 8, 2009 at 3:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
blower motor is located below the right side of dash, under glove compartment area.
Aug 10, 2009 at 9:49 PM
