Engine Performance problem
1994 Isuzu Rodeo Question 6 cyl Two Wheel Drive Manual 121 K miles
Idle speed will go as high as 2400 rpm then slowly return to near- normal. Did this before but cured its self in time. This time came on shortly after spraying intake with cleaner. Replaced IAC valve and throttle position sensor from wrecking yard but only improved for short time.
Havent found any serious vacuum leaks.
Jan 26, 2009 at 6:47 PM
