I have a 1994 Rodeo that is stuck in first gear. The gear selector moves through all gears and PRN work fine but D32L all are first only. When I downshift from 2 to L I can feel the transmission hesitate as if it is physically downshifting but the gear is the same. What has been done so far is:
Replace the transmission with a used one. No change.
Clean the Range sensor. No change.
Check the alternator output: 14.29 no load, 14.19 load.
In addition the dash lights for the gear indicator are dead and the Winter switch does not light up on the dash when pushed. The Power switch does as does the 4X4 light.
If I pull connector for the TCM the transmission behavior does not change. My repair book does not have a transmission wiring diagram in it.
ANy suggestions appreciated.
Feb 4, 2010 at 11:03 AM
