1993 Isuzu Rodeo Question clutch
1993 ISUZU RODEO
229,000 MILES • 4 CYL • 2WD • MANUAL
STACYSPOONER
how do i adjust my clutch
Dec 28, 2009 at 5:41 PM
On models with cruise control, remove clutch switch connector then loosen locknut and turn switch out until there is a gap between switch plunger and clutch pedal.
On models less cruise control, loosen clutch pedal adjusting bolt.
Loosen clutch master cylinder pushrod locknut then turn pushrod by hand to set clutch pedal height to 6.7-7.1 inches.
Tighten pushrod locknut.
On models with cruise control, proceed as follows:
Turn clutch switch until switch plunger is fully retracted against clutch pedal arm.
Turn out switch one-half turn, then lock clutch switch locknut.
Connect clutch switch connector.
On models less cruise control, tighten clutch pedal adjusting bolt until bolt contacts clutch pedal arm.
Ensure clutch pedal freeplay is 0.2-0.6 inch, if freeplay is not within specifications, repeat steps three through eight.
Dec 29, 2009 at 5:11 AM
