[quote:0cc19b89f8="fitter"]Heater problem
1991 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 150000 miles
Heater core leaking you said that you can bypass the heater core by looping inlet and outlet hose. How do you do that. do you have a picture.[/quote:0cc19b89f8]
That is all you have to do. You will have to go to your local auto parts store a get a heater hose connector. However you will need to know the size of the heater hoses, some are the same size and some have different sizes.
To bypass - locate the heater core inlet and outlet hoses under the hood usually on the passerger side. Then just disconnect them and using the heater hose connector put the 2 ends together.
Mar 14, 2009 at 10:32 AM
