1991 Isuzu Trooper, with 2.8 liter V6 also is running the TBI System. Mileage is 137,000. My problem is I have no gas spraying from the injectors. I have on one side of a single injector 12.4 volts with the key on. Nothing with the key off. There is no ground on the other side. The same with both injectors. I can manually feed the system with gasoline and it will start right up. Also, with power applied to the injectors, cranking the motor the injectors will spray.
With a nice cone shaped spray. If you can answer this question, I will donated enough for you to get a six-pack on your way home from work today! I need to figure this out now!! You help would be greatly appreciated, I have no manual on this vehicle. Thanks, again....Big Book of Matches!! :lol:
Mar 29, 2007 at 1:14 PM
