rear rotors
ISUZU
AKSILVERWOLF
I was in the middle of replacing my rear brake pads on my 93 isuzu rodeo LS 3.2L when I found that my right rear rotor had chunks out of it caused by the inside pad slipping out of place and allowing the piston to get chewed up hitting the rotor.
Now my problem.The rotor will not come off.I found a question that said "remove the axle nut" to get the rotor off.
Where is this thing.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mar 11, 2007 at 12:01 AM
2CARPRO JACK
  • 11,533 POSTS
Rear disc brakes are almost always "slip on".Im sure they are rusted on given your location.First soak the center with WD-40 then try tapping it from behind with a hammer or tapping the face of it to jar it loose (careful of the wheel studs)
Mar 11, 2007 at 8:10 AM
