Engine Runs rough under load
ISUZU
IBCHUCK
1998 Isuzu Trooper 3.5L DOHC, 121,300 miles, Auto Transmission. Engine surges when pulling up a hill. Accellerates normally on level road. Check engine light comes on after approximately 1 minute going up hill. Trouble code PO 306 is indicated (Misfie in cylinder # 6). No other codes.
I pulled spark pllug # 6. Gap was reset, no carbon deposits. Normal wear observed. Symptoms remain.
What could be causing this problem?
Nov 12, 2007 at 5:52 PM
BMRFIXIT
  • 19,053 POSTS
[quote:dbfcbe18cf="IBChuck"]1998 Isuzu Trooper 3.5L DOHC, 121,300 miles, Auto Transmission. Engine surges when pulling up a hill. Accellerates normally on level road. Check engine light comes on after approximately 1 minute going up hill. Trouble code PO 306 is indicated (Misfie in cylinder # 6). No other codes.
What could be causing this problem?[/quote:dbfcbe18cf]
u need to
check wire s coil injector comp
good luck
Nov 12, 2007 at 6:38 PM
