1998 Isuzu Hombre
1998 ISUZU
JOHN HARRIS
A friend purchased a 1998 Hombre with 77k. Less than a year ago a valve job was done on the engine. There is a distinct metal to metal noise coming from the engine. It appears to be either a broken/bad lifter or push rod adjustment issue. Does this 2.2 have hydraulic or mechanical lifters? If mechanical, are they self adjusters? What is the book repair time for replacing the lifters? Thanks.
Aug 16, 2006 at 12:19 PM
MIKEYBDMAN
  • 623 POSTS
[quote:155d71cc6e="john harris"]A friend purchased a 1998 Hombre with 77k. Less than a year ago a valve job was done on the engine. There is a distinct metal to metal noise coming from the engine. It appears to be either a broken/bad lifter or push rod adjustment issue. Does this 2.2 have hydraulic or mechanical lifters? If mechanical, are they self adjusters? What is the book repair time for replacing the lifters? Thanks.[/quote:155d71cc6e]
Hydraulic, no adjustment needed. All clyniders 7.0, one cylinder 6.3. Each one should cost around $20.
Aug 16, 2006 at 3:54 PM
JOHN HARRIS
[quote:b5bfd5fea5="Mikeybdman"][quote:b5bfd5fea5="john harris"]A friend purchased a 1998 Hombre with 77k. Less than a year ago a valve job was done on the engine. There is a distinct metal to metal noise coming from the engine. It appears to be either a broken/bad lifter or push rod adjustment issue. Does this 2.2 have hydraulic or mechanical lifters? If mechanical, are they self adjusters? What is the book repair time for replacing the lifters? Thanks.[/quote:b5bfd5fea5]
Hydraulic, no adjustment needed. All clyniders 7.0, one cylinder 6.3. Each one should cost around $20.[/quote:b5bfd5fea5]
Thank you. Do you know what the allotted book time is for replacing the lifters?
Aug 16, 2006 at 4:20 PM
MIKEYBDMAN
  • 623 POSTS
[quote:fc72645d74="john harris"][quote:fc72645d74="Mikeybdman"][quote:fc72645d74="john harris"]A friend purchased a 1998 Hombre with 77k. Less than a year ago a valve job was done on the engine. There is a distinct metal to metal noise coming from the engine. It appears to be either a broken/bad lifter or push rod adjustment issue. Does this 2.2 have hydraulic or mechanical lifters? If mechanical, are they self adjusters? What is the book repair time for replacing the lifters? Thanks.[/quote:fc72645d74]
Hydraulic, no adjustment needed. All clyniders 7.0, one cylinder 6.3. Each one should cost around $20.[/quote:fc72645d74]
Thank you. Do you know what the allotted book time is for replacing the lifters?[/quote:fc72645d74]
That is the times I listed. 7 hours to replace them all, and 6.3 hours to just replace 1.
Aug 16, 2006 at 4:23 PM
JOHN HARRIS
[quote:2468a8b710="Mikeybdman"][quote:2468a8b710="john harris"][quote:2468a8b710="Mikeybdman"][quote:2468a8b710="john harris"]A friend purchased a 1998 Hombre with 77k. Less than a year ago a valve job was done on the engine. There is a distinct metal to metal noise coming from the engine. It appears to be either a broken/bad lifter or push rod adjustment issue. Does this 2.2 have hydraulic or mechanical lifters? If mechanical, are they self adjusters? What is the book repair time for replacing the lifters? Thanks.[/quote:2468a8b710]
Hydraulic, no adjustment needed. All clyniders 7.0, one cylinder 6.3. Each one should cost around $20.[/quote:2468a8b710]
Thank you for the information!
Thank you. Do you know what the allotted book time is for replacing the lifters?[/quote:2468a8b710]
That is the times I listed. 7 hours to replace them all, and 6.3 hours to just replace 1.[/quote:2468a8b710]
Aug 16, 2006 at 4:51 PM
