1995 Isuzu BELTS
1995 ISUZU
LNORTHRU
Other Category problem
1995 Isuzu V6 Four Wheel Drive Automatic 120000 miles
THE SCREW THAT TIGHTENS AIR COND BELT IS STRIPED. WHAT CAN I DO?
Dec 8, 2007 at 2:58 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to remove the belt adjuster and replace the damaged adjuster bolt and nut, If you don't do both you will have further problems adjustib=ng the belt. If the Adj is part of the compressor mounting bracket , and not separate, you will be better of having your mechanic do this repair.
Mark (mhpautos)
Dec 8, 2007 at 5:31 PM
