1992 Other Isuzu Models wont start
1992 ISUZU
92Z71
Electrical problem
1992 Other Isuzu Models 4 cyl Two Wheel Drive Manual
i have a 92 isuzu pick-up with the 2.3 4 cylinder , it ran great , then it started only cranking when it wanted to, i could drive it to work fine shut it off and crank right back up, a hour or so later it wont start, then after setting for a while it would start, now it wont start at all, i checked and replaced fuel filter and all new gas , getting plenty gas, checked spark ha... found it no spark, now i have checked for 12 volts at the coil , yes , still no spark, changed cap and rotor, no spark ha.... bad module in distributor, changed the distributor HUH...... no spark ???? i have new distributor/cap/button/ and have 12 volts to coil (PLEASE HELP)
May 9, 2008 at 5:14 PM
Check if it has a camshaft and crankshaft sensors if so test it-could also be the computer not telling the control module to fire the coil-
May 9, 2008 at 5:23 PM
