1990 Other Isuzu Models NO ELECTRICAL SURGE AT THE SPARK PLU
1990 ISUZU
120,000 MILES • 4 CYL • 4WD • MANUAL
P10436
ONE DAY I AM TRAVELLING FOR A LONG DISTANCE FOR ABOUT 300KM. WHILE I WAS DRIVING IN 90KM/H THE ENGINE STOP. I TRIED TO FIND OUT WHAT HAPPEN. I FOUND THAT THERE IS NO SPARK ON THE PLUG. FOR YOUR INFO, I HAD JUST CHANGING ALL THE PLUG LAST MONTH.WHAT SHOULD I DO. TQ
Dec 15, 2007 at 9:45 PM
BLACKOP555
  • 10,386 POSTS
check for voltage at the coil, if thers power coming off then the coil is good and you should move to the distributor and rotor making sure it is not being carbon tracked and causing spark not to be emitted.
if nothign is coming from the coil you should check for voltage at the coil, if you have power replace the coil.
Dec 15, 2007 at 10:10 PM
