2002 Isuzu Axiom transmission fluid
2002 ISUZU AXIOM
TIGGLES381
Transmission problem
2002 Isuzu Axiom 6 cyl Two Wheel Drive
I was driving down the highway when i noticed alot of smoke coming from my suv. I stopped and looked under the suv and noticed transmission fluid all over the place. Did i blow my transmission?
Feb 20, 2010 at 7:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
wash down and top up the fluid, run the engine and check for any leaks around the transmission cooler lines, this is a common place to leak for these transmissions, start here.
mark (mhpautos)
Feb 20, 2010 at 8:17 PM
TIGGLES381
i washed it down and cant find where the leak is coming from. I would like to make sure that i have transmission fluid in it but again cant find where to put it?
Feb 21, 2010 at 10:31 AM
MHPAUTOS
  • 31,937 POSTS
Hi there, There is a fill point on the transmission, see pic, you should warm up the trans and remove plug No 1 this is the over fill plug, the oil should dribble out when plug removed this is also the fill point, Use dextron 111 transmission oil.
https://www.2carpros.com/forum/automotive_pictures/61395_trans_fill_1.jpg
Mark (mhpautos)
Feb 21, 2010 at 11:37 PM
