2002 Isuzu Axiom refill auto trans fluid
2002 ISUZU AXIOM
77,300 MILES • 6 CYL • 2WD • AUTOMATIC
SHER4548
hello,i have a small transmission leak in the lower oil pan,looks easy enough to repalce gasket,but where do i refill trans w fluid that has been lost.I see a tube w a yellow cap on the end just below the firewall in the middle of the firewall,is this where i fill transmission after removing yellow cap.thanks
Mar 28, 2010 at 9:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
there should be an overfill screw on the tranny assembly. this is where you add the Dexron III fluid, add it until it flows out over the overfill screw opening.
Mar 29, 2010 at 12:35 AM
