2000 Isuzu Amigo 2000 Amigo engine problems
2000 ISUZU AMIGO
42,000 MILES • 6 CYL • 4WD • AUTOMATIC
LULUG
I have a 2000 Isuzu Amigo with a knocking noise in the engine . It only has 42000 miles on it . It started about a week ago so I checked the oil and it was low so i added oil but over filled it mistake the noise did go away for a day or two but returned so I took it my shop at first they said they could flush the oil system out and see what happens an hour later they are tellin me I need a new engine By the way the check engine light just came on yesterday and the car is still drivable . My question is do you think I can just repair this engine or do I have to get a new one . Thank you for any help you can give me
Jun 1, 2009 at 8:09 AM
MMPRINCE4000
  • 8,548 POSTS
Engine knock is usually a main/rod bearing issue. If car was run low on oil, then engine will have to be rebuild, buy a remufactured engine, or get a used one from a junk yard.
Jun 1, 2009 at 8:32 AM
