1998 Isuzu Amigo fuel line
1998 ISUZU AMIGO
100,000 MILES • 4 CYL • 2WD • MANUAL
JOGU521
I replaced the fuel pressure regulator and it still has a problem starting. I have to turn the key over awhile before it catches. Like fuel isn't getting all the way up. When I drive there are no problems. After driving awhile it will start right up , but if it sits up awhile it takes time to start. What needs to be done ? Do I need to pressure up the fuel line where the F. P. R. sits in ? Or is there something else I should do to resolve this problem ? My # is 832 893 1246 if you would like to call.
May 26, 2010 at 1:30 PM
OBXAUTOMEDIC
  • 3,711 POSTS
It could be a weak Fuel Pump and or a bad FPR.
Try this next time...
Turn key to on possition without starting then back off. do this 2 or 3 times then try starting. If starts up replace FPR.
May 26, 2010 at 1:49 PM
