slow shifting between second and third gear with engine revving excessively
2005 HONDA CRV
163,000 MILES • AWD • AUTOMATIC
M_J_C
  • 12 POSTS
Car takes a while to shift between second and third gears. Car also revs excessively when changing gears. For instance, when I am on the highway I will accelerate to sixty mph and the car revs loud at 4,000 rpm. If I relieve pressure on the gas pedal and then immediately apply it again, it then shifts gears and the rpm's drop to normal. When I am slowing down from highway speeds it will jerk as its de-accelerating from third to second gear.
I realize this is likely transmission related. But I am hoping there could be an easier solution? Throttle body dirty? Spark plugs? Thanks
Jul 5, 2017 at 8:18 AM
It sounds like you have a shaft speed sensor that has gone out, please run the codes to confirm. Here are a couple of guides to get you started in the right direction.
and
https://youtu.be/f3bETtCIdxM
Please let us know what happens, we are interested to see what it is.
Jul 7, 2017 at 12:01 PM
M_J_C
  • 12 POSTS
Thanks Ken. Drove the car yesterday and it was noticeably worse. Jolting when shifting through gears. Got a check engine light and the codes were: 62-1, 83-1, P0685.
Hoping its just a battery cable or pcm relay. Ended up taking it to a mechanic with proper diagnostic tools (and for a separate issue). Will update when solved.
Jul 7, 2017 at 2:11 PM
Jul 7, 2017 at 8:01 PM
M_J_C
  • 12 POSTS
At the moment this is thought to be a bad battery. Trying the new battery for now -- so far so good. Possibility that its a bad starter. Mechanic also suggested I have the software updated at a Honda dealer (this is a 2005 - is this really necessary? Also -- how can I find out if I have the most up-to-date software already?) Will update this as things progress.
Jul 12, 2017 at 7:00 PM
Jul 13, 2017 at 3:50 PM
M_J_C
  • 12 POSTS
I had the battery replaced and the problem is now worse. When driving, I get a noticeable shudder between 1st and second gears (or a jolt when it switches). Today while this happened it was accompanied by a click sound from the passenger side (fuse box?) until at one point the wheel froze up and it went into limp mode. I'm worried now that this is a problem with my PCM. Could a faulty fuse or relay in the passenger side fuse box cause my car to shudder between gears? Or cause it to go into limp mode? Thanks
Jul 13, 2017 at 4:30 PM
It sounds like a speed sensor, please scan the computer for codes.
Jul 13, 2017 at 5:20 PM
M_J_C
  • 12 POSTS
The code I have is P0685.
Question: If it is a bad relay (PGM-F1), do I need to disconnect the battery when I check the relay? Or if I replace it? Also -- if it is a ground wire (G101 perhaps) - do I need to disconnect the battery to remove the ground to clean it? Or can I do all of this while the battery is attached? I am trying to troubleshoot small things before I bring it back to the shop. Thanks
Jul 14, 2017 at 7:25 AM
Yes it could be a bad PGM relay which is a common problem. check the relay with the battery connected and clean the ground and positive to the battery
Please let us know what you find.
Jul 14, 2017 at 9:41 AM
