Issue with changing gears (Auto Transmission)
2002 HONDA CIVIC
140,000 MILES
JAYCE99
Hi there,
So I'll keep it as short as possible - for the first 5-10 minutes after starting the car, going from gears 1-2 and then 2-3 has about a 1 second delay before it actually changes and the RPMs go up to about 4k RPM (instead of the normal 3k RPM) during that delay period before the gears change. After the first 5-10 minutes, it seems to change gears normally.
What would be causing this and how much would it cost to fix (I'm hoping not many hundreds or thousands of dollars).
Thanks in advance,
-Jayce
Sep 29, 2013 at 7:39 PM
CARADIODOC
  • 34,306 POSTS
That's called "engine runaway" and it's commonly caused by worn clutch plates in the transmission, but if it shifts normally after it's warmed up, that points to a plugged filter. Actually, it could be a combination of both causes. It is normal for the clutch plates to wear, then it takes a larger volume of fluid to apply each clutch pack. It takes time to move a larger volume of fluid so it takes longer to fill the clutch packs and make them engage. That gives the engine time to speed up while it's waiting for a clutch pack to lock up.
That was the typical way an automatic transmission acted when it was giving you a year or two notice that it was going to need to be rebuilt. Chrysler's computer-controlled design overcame that engine runaway but it eliminated the years of warning so people are caught by surprise when a total failure occurs.
Your transmission may be not computer-controlled or the computer doesn't pay attention to that slippage. Regardless, since the problem clears up when the engine warms up, (at least for now), a partially-plugged filter could be contributing to the slippage. When the transmission fluid is cold it is thicker, and it's harder to pump it through the filter. I would start with a fluid and filter replacement to see if that helps. A complete transmission flush is much more expensive and not likely to help for this problem. To clarify, if the flush includes a new filter, it's that filter that is going to help, not the additional flush service. Flushing the transmission is helpful when valves are sticking. That will cause shifts to occur at the wrong times but they will still be solid when they DO occur. Your shifts are occurring at the right times; they're just taking too long to complete. That points to low fluid flow and a restricted filter.
An additional clue that points to the filter is that you notice the problem when it up-shifts into two different gears. That means two different clutch packs are involved. If plate wear was the cause of a slipping shift, it would only occur at first when going into one gear, not two. As the wear continued to occur, you would notice the slipping shift into the second gear months or years later.
Sep 29, 2013 at 11:32 PM
JAYCE99
Thanks for the information, it's very helpful.
Are you basically saying no matter if I do the repairs you mentioned that my transmission is going to die soon regardless? I just bought the car like 2 weeks ago too and I'm a student, so replacing the transmission already is going to kill me! =((
-Jayce
Sep 30, 2013 at 5:17 AM
CARADIODOC
  • 34,306 POSTS
Nope. I'm saying I suspect your transmission has normal wear that results in a need for a little more fluid to apply the clutch packs, and a restricted filter is preventing that extra fluid from getting through. If I'm right, that old filter placed in a new transmission would work okay, OR a new filter in your older transmission would also solve the problem. Obviously you wouldn't put an old filter in a new transmission, but what I mean is the problem is the result of both of these things together, a restricted filter and a need for more fluid.
Now, to add to the confusion, it is entirely possible the previous owner had the same problem and had the filter replaced in an attempt to solve it. Maybe there was nothing wrong with the old filter and all the trouble is being caused by the transmission wear. The car could last a long time like that without getting much worse. Don't worry about replacing the transmission until the symptoms do get worse.
I'm not familiar enough with your car to know how the transmission shift points are controlled. On older Chrysler products it was done with a cable or a linkage between the throttle and transmission. If that linkage was misadjusted, it would cause the transmission to shift too late, meaning at too high a speed, or it could shift too soon. Shifting too soon had the secondary symptom of exactly what you described. Ask your local mechanic to take a look under the hood and tell you if your car uses a "kick down" linkage or cable. If it does, an adjustment may help or solve the problem.
Sep 30, 2013 at 1:06 PM
JAYCE99
So I took it to Honda themselves and they tested it with a computer hooked up to it while driving. Supposedly, it showed an "internal fault" inside the transmission and they are saying the transmission needs to be replaced in order to correct it. They are asking $2,400 dollars for it, insane.
What's really a piss off is I bought the car less than 2 weeks ago, certified and e-tested and already a massive repair bill...
Oct 1, 2013 at 1:49 PM
CARADIODOC
  • 34,306 POSTS
Check with the place you bought the car from about a warranty. All the reputable new and used-car dealers in my city usually give a 30 day 50 / 50 warranty where you pay half the bill and they cover the other half. Problems like these pop up all the time and it is just bad luck that you bought the car right before that problem was about to occur. The dealer has know way of knowing that, but they offer the warranty to take the sting out of unexpected things like this. We do have one well-known crook who owns multiple new-car dealerships. He has figured out all kinds of ways to rip customers off. In this case he would give you an estimate for $4800.00, but he would start the conversation with, "good news, . . . we're going to pay for half of the repair. All you'll have to pay is $2400.00".
$2400.00 is a pretty good price for a rebuilt transmission, but I'm still not convinced it needs to be replaced, at least right now. When the dealer covers half the bill, they aren't really shelling out any money. In this case their actual cost would be around $1200.00 or maybe a little more. Basically the parts get paid for and the mechanic gets his wages out of the $1200.00 you would pay. The dealer doesn't make any profit. He loses the profit he could have earned from his mechanic working on another customer's car. Also, he still has the huge number of bills to cover related to keeping the doors open for business. When all of that is factored in, the business is losing money but they do that to try to help you out in gratitude for buying the car from them. This is also what some of the profit goes to cover from all the other cars they've been working on.
I think I would visit a transmission specialty shop for a second opinion first. Tell them you already had it checked but you value their opinion more. That shows you consider them to be your advocate, not your adversary. By nature, some people will go out of their way to make a competitor look over-priced or incompetent, so don't volunteer where it was checked unless they ask. Most competitors are still friends with each other and they try to help their friends whenever possible. Some of them might agree with the previous diagnosis without really looking deeper, just to make the other shop look good. Neither of those scenarios are uncommon or fraudulent, but knowing who looked at your car previously can sway the second mechanic's opinion or affect his comments. You want an impartial and honest opinion. You can even say, "I'll tell you who looked at it already after you give me your unbiased opinion. That removes any bias and prevents them from incorrectly agreeing with a shop they like or incorrectly cutting down a competitor they don't like.
Also be aware transmission shops are in the business of rebuilding transmissions, so that's what they're going to lean towards. There could be a case where they might know all yours needs is a new filter, but based on other tests they know another failure is going to occur in about two years. They can hope you come back in two years instead of going to some other shop, or they can take care of the current and future problems right now by selling you the rebuild. They could also be inclined to just sell you the filter and fluid change, as long as they're fairly confident that will solve the problem, because they know you will remember how much money they saved you and you'll come back in the future. That's how good business people build a strong customer base and look to the future. That's exactly the opposite of how General Motors approaches their business practices.
One last comment about computer-controlled transmissions, which it appears you have since it produced a diagnostic fault code. Chrysler introduced that design for 1989 models, then everyone else copied it years later. With their system, the mechanic can read a set of four numbers on the scanner called the "clutch volume index", (CVI). Those show the number of ccs of fluid it takes to apply each of the four clutch packs. As the clutch plates wear down, it takes more fluid to fill in behind them when applying the pressure. The computer tracks that volume and keeps updating the shift schedules to maintain that nice solid, crisp shift it had when it was new. An experienced transmission mechanic can tell by those numbers how much wear has taken place. They can't tell you how many miles or years are left because everyone drives differently, but they can tell you the approximate percentage of life that is left in the most worn clutch pack. If those numbers are low yet, that says clutch plate wear is not the cause of the engine runaway and a filter and fluid change may be all that's needed. If the numbers are high, replacing just the filter may solve the problem for a little while but it's not a good value if it will still need to be rebuilt soon. Mechanics are typically concerned with what's best for you and your car long-term, not just solving the immediate problem.
Oct 1, 2013 at 7:21 PM
