Issue of vibration
2008 NISSAN X-TRAIL
183,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
ZAHIRNIZAR
I have the vehicle listed above T30 model. it gets a vibration when the gear is engaged and also the vibration increases if the AC is on. Why does it happen? please give some solution if possible.
Jan 30, 2019 at 8:28 PM
SEVAG P
  • 405 POSTS
As a first step check engine mounts and transmission mounts.check visually if any hydraulic oil leak from them or the rubber is deformed (cutted).
Jan 31, 2019 at 10:15 AM
Also, if you could remove the serpentine belt and then start the engine to see if the vibration is still there? Here is a guide to help walk you through the steps:
https://www.2carpros.com/articles/replace-serpentine-belt
Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
Jan 31, 2019 at 4:39 PM
