Hello, and thanks for the video. Yes, you do have a coolant leak, so please be careful. Allow the engine to cool down before you check the coolant level and do not drive the car until it is fixed, or you might ruin the engine.
This video will help:
https://youtu.be/GSE9skKnOgY?si=ycd62fnfGWg0YZc1
It is difficult to tell here is it coming from by the video, but it looks like it is the radiator which is common. If you raise the hood and look you might be able to see where it is coming from.
This guide can help:
https://www.2carpros.com/articles/car-is-leaking-coolant
To change out the radiator you will need to discharge and refill the A/C system.
This guide will show you what needs to be done in case of a radiator change:
Jan 16, 2024 at 10:20 AM
