You are welcome.
Yep, that is what happens when the chain moves.
Remove the spark plugs and see if it cranks over.
I attached the code possibilities for you. The 2 codes have the timing chain in common.
There is no 339. Can you verify?
U0073 is a serial data line or communication line code.
DTC U0073 or U2100
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Vehicle > Initial Inspection and Diagnostic Overview
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptor
DTC U0073 00
Control Module Communication Bus Off
DTC U0073 71
ECU HS Bus Off
DTC U0073 72
ECU LS Bus Off
DTC U2100 00
Controller Area Network (CAN) Bus Communication
DTC U2100 47
Circuit/System Description
The serial data circuits are serial data buses are used to communicate information between the control modules. The serial data circuits also connect directly to the data link connector (DLC).
Conditions for Running the DTCs
Supply voltage at the modules are in the normal operating range.
The vehicle power mode requires serial data communications.
Conditions for Setting the DTC
The module setting the DTC has attempted to establish communications on the serial data circuits more than 3 times.
Action Taken When the DTCs Sets
The module suspends all message transmission.
The module uses default values for all parameters received on the serial data circuits.
The module inhibits the setting of all other communication DTCs.
Conditions for Clearing the DTC
A current DTC clears when the malfunction is no longer present.
A history DTC clears when the module ignition cycle counter reaches the reset threshold of 50, without a repeat of the malfunction.
Circuit/System Verification
1. Refer to Data Link References to determine which serial data system is used for a specific module. See: Information Bus > Initial Inspection and Diagnostic Overview > Data Link References
2. This DTC cannot be retrieved with a current status. Diagnosis is accomplished using the symptom Scan Tool Does Not Communicate with High Speed GMLAN Device or Scan Tool Does Not Communicate with Low Speed GMLAN Device.
Aug 20, 2020 at 5:41 PM
