Oxygen sensor replacement instructions?
2002 BUICK CENTURY
99,500 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
CYNTHIA R SCOTT
I have no codes relating to 02 and the heated 02 passes, but not the regular 02 sensor. The EVAP is failing as well codes p0449 and p0446 (no service engine light though,yet). EVAP has failed before without causing other things to fail or not complete.
Nov 6, 2019 at 11:18 AM
This could be a couple of things. First and foremost it could be the o2 sensors, purge valve or a couple other items as well.
I attached the testing that we need to run through in order to figure this out for sure.
Here are some guides that will help with this:
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
However, I also attached the instructions on how to replace the o2 sensors as you requested.
Run through this material below and let us know if you have questions.
Feb 12, 2021 at 6:45 PM
The check engine light comes on. It called for bank one o2 sensor. So I went ahead and changed both o2 sensors. I cleared the code and it stayed off until she accelerated hard getting back on interstate. I thought maybe it was a faulty sensor so I replaced the first one again. Same result. Plus, the mileage isn't as good as it once was. Other than that a great car. Any help is appericated.
Feb 15, 2021 at 9:58 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
What were the exact code? slow reaponse? heater circuit? there are several codes for the o2 sensors, and some are mixture codes that may be a problem with the fuel injection that is causing the o2 sensor to not be able to control the mixture
FAB22
Where are the o2 sensors located and how difficult are they to change? Also is there any type of computer resetting that has to be done?
Feb 15, 2021 at 9:59 AM (Merged)
Hi:
The O2 sensors are on the exhaust. One is upstream and one down stream (cat), and they almost look like a spark plug. They are easy to replace. They just screw out and in and have an electrical plug. However, I recommend that you purchase antiseeze and put some on the new sensor's threads before replacing them. Also, you don't need to do anything to the computer.
I hope this helps.
Positive feedback is appreciated.
FREELANCER
Engine Performance problem
1998 Buick Century 6 cyl Front Wheel Drive Automatic
how to replace o2 sensors
BLACKOP555
  • 10,386 POSTS
turn on vehcle and let it warm up. be careful exhaust will be very ot.
with engine off locate oxygen sensor that needs replacement and disconnect the connector keepign it away from the hot pipes.
after that you will have to use a special socket or a box end wrench and procede to loosen it making careful not to strip it out or hit the hot exhaust.
when installing the new one use antiseize compound.
DEERWENA
Engine Mechanical problem
1991 Buick Century 6 cyl Automatic
Can some one please tell me where the oxygen sensor is located
1991 Buick Century V6-204 3.3L VIN N FI RH Rear Of Engine.
https://www.2carpros.com/forum/automotive_pictures/12900_os_1.jpg
Bottom Rear Of Engine, On Exhaust Manifold
