My truck listed above is making a rattling sound occasionally. It happens under acceleration from 2-3k RPMs and goes away if I lift off the throttle. I flushed the crank case, ran intake valve/combustion chamber cleaner through the intake to remove carbon, ran injector cleaner through a couple times, replaced the spark plugs, and started using premium fuel. Nothing has caused the problem to go away.
Mar 27, 2025 at 8:49 AM
