Haven’t driven the car in a year and some change after my driveshaft snapped and put a hole in my transmission. I finally decided to fix it and had the transmission replaced, clutch replaced and driveshaft. After repairs my car would not start. Mechanic suggested it could be a compression issue so I took it to a BMW specialist. They found my battery terminal was filled with water and burnt out the battery case and cables and replaced them. Now my car cranks but still won’t start and they also believe it could be a lack of compression or timing issue. I’ve already put $3,100.00 into the car and want to have it fixed but the BMW specialist is saying I’m looking at another $2,500.00 if they have to remove the valve cover to check the timing etc., and that still could not be the issue. I don’t want to just keep pouring money into this car for no reason but I need a vehicle. What should I do?
Jul 2, 2020 at 8:26 AM
