Check engine light on with code p1709 and VSA light is on?
2002 ACURA TL
160,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
BENJAMINTHERERRIBLE
  • 58 POSTS
2002 Acura tl type s D5 light continually blinks. CEL is on (p1709), VSA light is on, and the ! Inside the yellow triangle is on. Seems like its shifting harder than should. Also, at low throttle and lower speeds, intermittent loud buzzing(?) Sound from the engine bay
Does that sound like a neutral safety switch?
Sep 13, 2025 at 3:51 PM
Yep, this would be a gear range sensor issue (neutral safety switch). Here is the location so you can swap it out and then clear the codes. Check out the images (below). Let us know how it goes.
Sep 14, 2025 at 12:08 PM
BENJAMINTHERERRIBLE
  • 58 POSTS
thanks for the prompt response.
So I ordered the part, but the earliest i can get it is Friday..
That said, (and I'm guessing i already know the answer to this), but is it safe to drive it (maybe 30mi/day) until then, or would I be doing significant damage to the transmission by doing so?
Sep 15, 2025 at 3:32 PM
I would not drive the car, I don't think it would shift correctly anyway.
Sep 16, 2025 at 9:29 AM
BENJAMINTHERERRIBLE
  • 58 POSTS
it actually shifts pretty normally.
does that change anything as far as the diagnosis?
Sep 16, 2025 at 1:58 PM
BENJAMINTHERERRIBLE
  • 58 POSTS
It might also be worth noting that every once in a while, when accelerating from a stop or low speeds (again only under light throttle), it will have a bit of a bucking bronco effect.
Sep 16, 2025 at 2:09 PM
Okay, it might be fine to drive but I don't want to tell you that and then have something bad happen.
Sep 16, 2025 at 4:50 PM
BENJAMINTHERERRIBLE
  • 58 POSTS
Noted. If i do, it'll be at my own risk.
Ill let you know if NSS replacement fixes the dash lights.
Sep 16, 2025 at 6:32 PM
Sounds good, be sure to clear the codes once completed.
Sep 17, 2025 at 8:25 AM
BENJAMINTHERERRIBLE
  • 58 POSTS
Installed the NSS and cleared the codes.
After turning the key to the acc position, the code/lights came right back after a few seconds.
What should I look into next?
Oct 2, 2025 at 11:32 AM
Yep, is because the shifter is not seeing what the transmission is which can be due to a worn shifter cable, can you move the shifter into park through 1st gear cleanly?
Oct 7, 2025 at 10:50 AM
