It started pouring rain mid job and I really want to get it under the car port but I can't start the ignition obviously because I have no transmission fluid in there.
I just tried to push it in neutral with no luck because I'm on an angle and can't get momentum. Anyway, I just realized I know fuel injector activates when you turn the key. Did I damage transmission by turning to to switch gears (without starting the car) to push it? Thank you
Jan 24, 2020 at 1:04 PM
