rattling or tumbling around noise coming from under the truck
1997 CHEVROLET TRUCK
160,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HIPPIECHIC
  • 9 POSTS
I started hearing a noise coming from under the truck, like something was rattling or tumbling around. Could not pin point it since it is hard to drive and be under the truck so I removed the differential cover to make sure nothing had broken there. It was all good no metal shaving, so replaced the gasket and bolted it back on. Then some said I had a bad bearing and since I had not replaced those I pulled both rear axles out and replaced the bearings. All the u-joint look good and I cannot turn the driveshaft with my hand. So after replacing the bearings it seemed that the noise was more toward the front and I started getting a loud noise after starting and letting it run for a few minutes. The noise sounded to me like the noise you get when a heat shield comes loose. Anyway when I drive it, it will drive fine and then it stops advancing, like I am pressing on the gas but it is not going. If I stop the truck and put it in park and turn it off and then restart it and put it in gear then it will go again. Then after eight or ten blocks it does the same thing again and I have to stop and put it in park and turn it off and restart it. Could it be the inside of my catalytic converter causing this? Stuck.
Sep 21, 2016 at 12:36 PM
SATURNTECH9
  • 30,869 POSTS
Yes I was thinking about a cat that has broken loose inside the whole time when I was reading your description of the noise.When the noise is present take a piece of wood and jar the car around and lightly tap on it.See if it rattles.
Sep 22, 2016 at 4:55 PM
HIPPIECHIC
  • 9 POSTS
Ok thanks I'm gonna go ahead a try my next fix.
Sep 22, 2016 at 10:47 PM
SATURNTECH9
  • 30,869 POSTS
Keep us posted.
Sep 23, 2016 at 7:12 AM
HIPPIECHIC
  • 9 POSTS
Ok well unfortunately after removing the cats and replacing with straight pipes I still have that noise that sounds like a heat shield rattling and after going 6 or 7 blocks the truck stops pushing forward. Once I stop and put it in park and turn off the key. Then I restart the truck and put it in drive it will go again for another 6 or 7 blocks before I have to stop and turn it off again, RRRrrr very frustrated please let me know of what other solutions you might have.
Thanks,
Hippiechic
Oct 11, 2016 at 7:57 AM
SATURNTECH9
  • 30,869 POSTS
So have you checked for codes in the computer yet?It sounds like the computer might be putting it in limp mode.
Oct 11, 2016 at 10:36 AM
HIPPIECHIC
  • 9 POSTS
Well thanks for all your advice in my attempts to resolve the issues with my pickup. Unfortunately my hopes of it being something other than the transmission failed. It was the tranny. Something inside the tranny broke apart so I had to replace the tranny after all. On the upside also got other items replaced in my endeavor of not wanting it to be the tranny. And I should be grateful in a way cause those trannies usually only last for about 170,000 and I am at 254,000. Thank you again you guys are always a big help. Till my next adventure.
Dec 12, 2016 at 9:50 AM
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Dec 12, 2016 at 9:57 AM
