Hello again,
Okay, so let's start by explaining how we are going to checking the circuits. You are going to need a multi-meter. We are going to be using it primarily two different ways. 1) Checking for voltage - To do this you are going to put the multi-meter switch in VDC(Volts Direct Current). Select the 20V setting. Your vehicle's electrical system runs on 12 Volts DC, so when we are checking for voltage, put your multi-meter in this setting and usually we are going to be looking for 12-12.6 volts. To simplify this we will call this battery voltage.
2) Voltage Drop - This is the best way to check for resistance and continuity in your vehicle's electrical circuits. To do this testing your vehicle will will have to either be running or have electricity flowing in the circuit. You will have your multi-meter in the same setting as before and you will measure a piece of the circuit. For instance if we wanted to do a voltage drop test on a wire, you would back probe the connector with a safety pin in the cavity where the wire is and do the same on the connector of the other end of the wire. Next you will touch a black probe to one safety pin and the red to the other. Measure the voltage. It should not be more than 0.1 Volts. If there is more than the wire has unwanted resistance and must be replaced. This type of testing will expose any damaged parts of the circuit so they can be replaced.
Okay, I know that that's a lot to take in. So let's make sure again that your battery and the terminal lugs are okay. Let's test the battery voltage to see where the battery stands. Put your multi-meter in #1 setting. Touch the red probe to the positive battery terminal and the black terminal to the negative terminal. Write down what you find. To show you it's okay if you get the probes mixed up and put them backwards, switch the red and black probes so that the black probe is touching the battery positive terminal and the red is touching the battery negative terminal. Write down this reading. Now start your vehicle, and leave it in park. Get out and follow the big wire from your batteries negative terminal to where it connects to the frame. Put one test probe on where it connects to the frame and the other test probe on the where it connects to the battery. Write down the voltage on the multi-meter.
Get back to us with the voltage readings we had you test these techniques with and we will go from there.
Thanks,
Alex
2CarPros
Mar 29, 2019 at 1:54 PM
