Erratic spark
1990 PONTIAC FIREBIRD
200,000,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
JOELCOOK
I took out v6 and put in 350 Vortec with old style headed an Eldelbrock 1406 carburetor and intake an Accel distributor with super coil with vacuum advance timing set at 35 total 42 with vacuum. Ran great, but now it misses. I used my timing light on all the wires an light was erratic, not steady at idle. But not while light throttle or without power. What would cause this?
Mar 7, 2016 at 8:59 PM
HMAC300
  • 48,601 POSTS
run the timing back to something like 12 initial at idle or 10 even. check distributor cap for cracks and resistance of coil. You may have pre-ignition running that much timing and made the valves tulip.
Mar 8, 2016 at 6:59 AM
JOELCOOK
Set at 10 initial have 23 mech. Total at 33 still rough idle and unsteady spark an no power loss.
Mar 8, 2016 at 8:37 AM
HMAC300
  • 48,601 POSTS
Check your compression and for vacuum leaks. if you installed a big-lift cam in the car that could be your problem as well as it will need to idle faster due to vacuum loss. Also check the coil for leakage as it may have cracked, spray water around it and make sure distributor cap wiring is in the correct order.
Mar 8, 2016 at 9:32 AM
