I am told I have a bad inverter. My question is, can I put a used inverter from the same year and model?
2009 CHEVROLET SILVERADO HYBRID
180,000 MILES • V8 • 2WD • AUTOMATIC
RON PELLO
  • 31 POSTS
I am told I have a bad inverter. My question is, can i put a used inverter from the same year and model?
Aug 16, 2019 at 9:47 PM
Good morning,
Yes, you could but it would be a risky and expensive move. If it is bad, you will need a new one. They are about $1,500.00.
Did you check to see if the part has any warranty left?
Aug 17, 2019 at 5:19 AM
RON PELLO
  • 31 POSTS
i did not find a used one. i found a new one from gm direct for $3,299,00, i don't know if that is the problem. that is what the guy working on it says.
a after he put in a battery. the big one. he says the only codes that came up were,POC76-00, CO561-00,CO775-00, WITH THE POC76-00 SHOWING 4 or 5 more times but displaying different data. now the codes are U1885-00 , B1001-43 , POAID-00 , U1817-00 , U1843-00 , CO561-71 , UO100-88 , CO242-00 , PO700-00 , POAID-00 , B1001-00 , UD293-00 , U1817-00 , UI843-00 POC76-00 , and some of them repeat themselves with different explanations , the POC76-00 must be in there at least 12 times with a different meaning. from what i am getting from him it looks to me that he decided that my module needed reprogramming. while he was reprogramming the battery went dead. he said any way. it was only 3 days old tho. so i think he would have lost the module. i think it is like programming a bios in a computer. if you lose power while installing. it is lost forever. not sure tho. he then decided to put in a used invert-er. after install he said it would not read because it had wrong info in it. so he installed my chip in it but he says the part of my invert-er that stores my info is the part that is broken so the new invert-er would not read it. so now he says i need i whole new invert-er assembly. after reading all night about this stuff. i think after changing the big battery and the little battery and a whole new invert-er assembly with a new control module and transmission module and a air conditioner compressor. with the exception of the cooling system. that is all there is . am i right?
Aug 17, 2019 at 6:55 AM
You are correct. Once the module has lost power while programming, the module is junk.
It must be replaced and programmed. Since he did this, he should be responsible for that replacement. As a technician, he should know that you put a battery charger on while programming.
Aug 17, 2019 at 7:00 AM
RON PELLO
  • 31 POSTS
also, a lot of the codes say lost communication of this or that but then they all say status this ignition, pass,fail, after codes cleared,fail past history. is that telling me that after the big battery was installed that there was high current,then at one time he tested it and these codes passed. but he tested again and they failed and that is all the history there is because the codes were cleared? and if the battery control module lost its information, would that cause all the communication losses. I know its a lot to ask. but I have learned just enough to make me think i can figure it out. and try and make sense out of maybe nothing. Thank you so much. I am wondering if maybe my 12 volt battery went bad. because it was still original. and i drove all the juice out of the big battery. and if i would have had a bidirectional reader i could have changed the program to charge the battery with a jump car with a charger on it. purchased a new 12 volt and been good to go. would that have worked if that is possible? because there were no loss of communication codes until the invert-er was messed with. up until that point it just would not turn over.
Aug 17, 2019 at 7:15 AM
RON PELLO
  • 31 POSTS
And really thank you Mr. Roy.
i don't think he will take responsibility for any thing, but i feel much better know a thing or two. very nice service you are giving people.
Aug 17, 2019 at 7:20 AM
You are welcome.
The first thing that needs to be done is change the invert-er and program the module.
Then recheck for codes. That could be the reason for no communication.
Aug 17, 2019 at 7:24 AM
RON PELLO
  • 31 POSTS
i am sorry but one more question. the program or scanner he used . he posted the results on google pictures. the program show my car and VIN. and it also say the time is 13.26 but on the pages that have the scan results it says 9;31. I think 13.26 is military time for 1:36. would there be another reason for the times to be different?
Aug 17, 2019 at 7:27 AM
Send me the link to see.
Aug 17, 2019 at 7:30 AM
RON PELLO
  • 31 POSTS
he says, "this is after the battery change and before the inverter swap"
https://photos.app.goo.gl/zfSuCWacDyagKELn7
Aug 17, 2019 at 11:15 AM
RON PELLO
  • 31 POSTS
After used invert-er was in and after GM's service programming July 12th. https://photos.app.goo.gl/9fETLkfHnxu5zMws5
Aug 17, 2019 at 11:16 AM
RON PELLO
  • 31 POSTS
Final scan with the used invert-er containing the old invert-er's chip that includes the original VIN number, confirming the newer invert-er is communicating and installed correctly but the old invert-er's board is what was defected bringing back the code P0C76. Picture of board and codes below:
https://photos.app.goo.gl/LLWuGyKvkLEjLALf7
Aug 17, 2019 at 11:20 AM
RON PELLO
  • 31 POSTS
Hi Roy. I just copied from my email then pasted here . maybe if you have a little time you can take a quick look. I am being told this is all the codes. but looking at the vehicles in his test list I can see that the 2010 Chevrolet Silverado is on the list of vehicles tested more times than the code pages he sent. I don't want to sound stupid if I ask him about it. He talks real slow and acts all offended when I ask about anything. It would be nice to be able to ask him questions that I haven't guessed about. what do you think?
Aug 17, 2019 at 11:28 AM
RON PELLO
  • 31 POSTS
well, If some one is going to take the time to look at my problem and help me get this thing going I should give all the information that I have received. Thursday after he told me I needed a $5,000.00 part. I asked for all the recorded codes he had. 4 hours later he sent me this:
Aug 17, 2019 at 11:50 AM
RON PELLO
  • 31 POSTS
Hi Ron, part of the problem at first is since the small battery was disconnected (I know I recommended that over the phone to see if you can drive the car), the codes and freeze frame were all clear. The hybrid battery didn't have a code but was giving 0 voltage instead of 300+ (on the scanner and manually while bypassing safety switches). I tested individual relays manually, and one of them didn't open up. I couldn't find any bad batteries anywhere to get parts from, so I suggested getting a used battery to get it over with. Since then, the hybrid battery gives 300v and that issue was resolved.
After hybrid battery install July 4th, before ordering inverter
After used inverter was in and after GM's service programming July 12th
Final scan with the used inverter containing the old inverter's chip that includes the original vin number, confirming the newer inverter is communicating and installed correctly but the old inverter's board is what was defected bringing back the code P0C76. Picture of board and codes below:
There were several other hiccups like the low power issues that the car was lying about (out of humor, since the small battery was not always low) ...etc that added more time.
Attached is what a customer was quoted a couple months ago, but we changed a used one for them instead.
As discussed, I don't want you to feel pressured to spend more money with us since we have our car. This is not the way we do business.
You have the option to buy the part yourself, you have the option to get your car back, and you have the option of having a third party validate or check the work that is done.
One thing to keep in mind, the invert-er is a special order is not available in stock anywhere I called. 2-day shipping option starts after the part is delivered from GM.
Aug 17, 2019 at 11:52 AM
I got all the information. I still don't see where there is new not used invert-er.
Why is he telling you it needs $5,000.00 part. He started this issue.
Aug 17, 2019 at 12:18 PM
RON PELLO
  • 31 POSTS
he is telling me that all the stuff he replaced in the truck happened because the 12 volt battery going dead. this started at my house and soon i had towed it to a shop in Santa Clara were he said he had all the correct test equipment. so he now says that the reason that the 12 volt battery went dead as well as the 300 volt battery. and the reason the truck still wont turn over is because it needs a new invert-er assembly,that cost $5,500.00 just for the part. but he will install it for free. i gave him $1,500.00 for a rebuilt 300 volt battery.that he said he installed. but i have no paper work or record of any kind except what i showed you. I don't even know if there is a shop. am i getting scammed? when i write all this down and read it it isn't sounding good.
Aug 17, 2019 at 1:02 PM
It did not fail from the 12 volt battery. That is inaccurate.
He made a big mistake that caused you problems. He needs to stand behind his mistake and fix it for you. He will get paid from his insurance company for a bad repair.
Sorry, this guy is not helping you. The part on Alldata is only $3,499.00. I would like to know where he came up with $5,000.00.
Aug 17, 2019 at 1:07 PM
RON PELLO
  • 31 POSTS
thank you Roy.
Aug 17, 2019 at 1:26 PM
You are welcome.
Always glad to help.
Aug 17, 2019 at 1:28 PM
SIMPLEAPPROACH
This thread it's incredibly helpful!
Simple summary...
1. I bought a 2009 hybrid Tahoe.
2. Dealer deduced 4 things, I've find the first 3 - new 12V battery, new ignition, (refurbished) hybrid battery...
3. Final conclusion- hybrid inverter module... power is not transferring from hybrid battery to start the truck
4. I bought a used Hybrid inverter module (and ECM).
What's the process for properly installing that used inverter module?
A. Any obvious pitfalls?
B. Any clarity on the earlier take aways?
i) swap the chip in the inverter with the original to retain the matching VIN.
ii) keep it powered with a battery re- programming. other?
Oct 26, 2021 at 7:02 PM
SIMPLEAPPROACH
*Find = done
Note: after the first 3 options didn't work, I replaced the original ignition and hybrid batteries (and was refunded).
Oct 26, 2021 at 7:03 PM
SIMPLEAPPROACH
Typos... ailerons = options
Oct 26, 2021 at 7:04 PM
Thank you for the update. Is everything working as it should now? We're interested in knowing.
Oct 31, 2021 at 6:22 PM
CARLFEF
  • 0 POST
cafergot tablets buy online
Sep 22, 2022 at 8:30 AM
DAVIDUNDUM
clomid price in india online
Sep 23, 2022 at 7:24 AM
RON PELLO
  • 31 POSTS
Well, it has been quite a while. But if anyone is interested. The power inverter system is vehicle specific. If it goes bad a new one will be required and after installation. It then needs to be programed to the vehicle it is installed on. Only a dealer has the software to do that.
We found a young honest mechanic that works for a dealer. He did it on the side for us. Gave us his price and purchased the inverter assembly. Installed and programed all for $1500.00. Parts and labor. Took him one evening after work. Very nice young gentleman.
The mechanic that caused this got away with it. The wrecking yard that sold us the used inverter. knowing that it was not usable. They got away with it. And the Chevrolet Dealer. In San Leandro California. The dealer that gave us a Quote of at least 10 thousand dollars.
They did not do any more work on the truck other than charging us $500.00 for a diagnostic check. And a super inflated price . But gave us all a perfect example of how the dealerships are screwing people.
All these people are still working on people's automobiles. So sad.
Thank you for all your help and input.
The truck has been working fine now for a couple of years. All that was wrong with it was. The 12 volt battery went dead. The truck was down for a li
ttle more than a year.
Sep 23, 2022 at 12:54 PM
Ron,
Thank you for that update and information. I assure you; it will help others.
Take care of yourself and please feel free to come back anytime in the future.
Sep 23, 2022 at 8:35 PM
CARADIODOC
  • 34,306 POSTS
Hi guys. I too am very happy to read it is solved. Please understand the majority of new-car dealers and independent repair shops are honest and reputable. Your experience at your Chevy dealer might also be partially not their fault. In my city, we have a Chrysler dealer, a GMC dealer, Cadillac dealer, a former Ford dealer, and a former import dealer who worked real well together. We would borrow service manuals among shops, fix each other's trade-ins, and help over the phone. The one notable exception is the local Chevy dealer. He works cooperatively with no one, and has more ways figured out to legally separate you from your money than even GM has dreamed up. One of GM's tricks, as you've learned, is the need to program computer modules to a specific vehicle, and then they can't be reused on another one. That makes them worthless to the salvage yards. Of course GM will not release the ability to do that to the independent shops. Trying to put them out of business. It's that type of unfriendly business practices that first came to light at multiple classes I attended over the years. Unfortunately, whatever GM comes up with to cost you money after the sale, other manufacturers copy it a few years later. Ever wonder how the manufacturers can be so profitable, but they aren't able to sell their cars right now?
Our Ford and import dealers were bought up by the Chevy dealer, so now a huge percentage of buyers who insist on a new GM vehicle will drive 15 or 34 miles to a dealership in a nearby city. Incidentally, his service bays are always nearly empty at all of the dozen dealerships he has acquired. His reputation is well-known, but that doesn't reflect on all the other decent dealerships.
When you look at the two-page list I put together for my students, you'd be amazed at all the expenses dealers have to meet government regulations, from taxes, insurances, manufacturer-mandated procedures, environmental regulations and fees, to all the expenses associated simply with having 50 or more employees and you'd be unable to figure out how they can do that when only charging $100.00 per hour. And understand well over half the employees don't bring in any income to the business. It's all on the backs of the dozen mechanics and body shop personnel. Much of the hourly labor charge goes to cover them for things people have sued for in the past. We all pay for that now.
I too tried to help customers out in the past, but that can come back to bite your mechanic. When I worked at a Sears Auto Center, a mechanic would have been fired for doing what yours did for you. If anything goes wrong with the repair and you're involved in a crash or a fire, there's going to be a lawsuit. Where does the liability start and end? Sears was worried about that, plus, any work we did outside of the job was considered taking work away from the business. Other than GM, no company knew more about how to increase profits than Sears. My manager even tried to fire an employee for using his employee discount to buy a Christmas present for a friend.
I'm happy everything worked out in your story, but remember there's always the other side to consider. We also had one very unscrupulous independent shop owner who has since run out of customers, (victims), and is out of business. I will never defend a dishonest business owner, or a dishonest customer, but they do give the entire industry a huge black eye. I hope your next repair story leaves you with a smile on your face.
Oct 1, 2022 at 1:22 PM
