2000 International Truck s oil in the cooling system and wat
2000 INTERNATIONAL TRUCK
KUTTIE48
Engine Mechanical problem
2000 International Truck s Manual 300000 miles
what is causing engine oil to be in the cooling system and water in the engine oil?
Apr 16, 2009 at 8:19 PM
BUDDYCRAIGG
  • 2,262 POSTS
blown head gasket
cracked head
cracked block
leak in the water over oil cooler
dont run it this way. you'll kill the engine.
Apr 16, 2009 at 9:38 PM
TYDUON06
The most common cause that we've seen for coolant in the oil is from leaking piston liner sleeve o-rings, also the other common cause for coolant in the oil is usually from your oil cooler.
To check for liner o-ring leak causing water in oil we recommend removing oil pan fill cooling sys. with water if low and pressure test cooling sys. at coolant tank with pressure tester and look for coolant leaking down oil pan.
Sep 17, 2009 at 1:24 AM
