1979 International Scout loss of ppower
1979 INTERNATIONAL SCOUT
KIRKBAR
Engine Performance problem
1979 International Scout V8 All Wheel Drive 100000 miles
loss of power only when put in gear? timing,plugs,cap,rotor, coil, carburator. all correct?
Oct 5, 2010 at 8:46 PM
HMAC300
  • 48,601 POSTS
if everything is ok like carb and ignition, then make sure your filters aren't plugged, like fuel and air. then put a vacuum gauge on the intake and if your vacuum is 15" or below at idle check for a plugged exaust. it may have jumped time at the timing chain as well due to your mileage...
Oct 24, 2010 at 2:59 PM
