1981 Other International Models timing a 345 international
1981 INTERNATIONAL
85,000 MILES • V8 • 2WD • MANUAL
MKIRKMAN99
does anybody know the proper procedure for timing a 345. i keep hearing different things and don't know wich is right. i've heard time it off number 1, and i heard time it off number 8. i think it is 8 but i've been told set it at TDC and been told 6 deg. adv. also........ please help
Aug 9, 2009 at 4:20 PM
HMAC300
  • 48,601 POSTS
there a few things with this vehicle. It is timed off of #8 cylinder. If it is a california emmission then it is TDC no matter if it is a stick or automatic. If it is not a california emission vehicle then if you have a 2210C carb it is 5 degrees TDC and if you have a 2300EG carb it is TDC. there should be a tag or casting on the carb to see which is which.
Nov 12, 2009 at 2:34 PM
