It sounds like the central junction box has gone out, but we should check the fuses and grounds for the system, here is a guide that can help:
Here are the wiper wiring diagrams so you can see how the system works and which fuses to check with the ground locations. Also, you may be able to do a CAN scan to see if any codes come up for the central junction box. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Here is how to change the CJB out in case you need it. Check out the images (below). Please let us know what happens.
Apr 25, 2024 at 10:26 AM
