When stationary, everything functions as intended. Power steering works, and no other lights are on. In car setup, everything functions as intended and I am able to set the tire pressure. However, every time I put it into first or reverse and start going, power steering, abs, traction control, airbags and tire pressure lights come on and these functions seem to cease to function. Wheel speed sensor had been damaged, but was replaced. Everything is fine at a stand still but quits when moving. Speedo and all other functions are operational, and there is no check engine light nor codes read by a FIXD code reader.
Jun 4, 2023 at 9:54 AM
