intermittent vibration, humming, shaking
2005 MAZDA 3
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
SSSUSANNN
My car recently began to shake, vibrate, and make humming sounds intermittently. The check engine light was recently reset. This seems to happen more at higher speeds.
I drive on the highway for ten minutes vibrating, then okay, then more vibration when I accelerated, No idea if a tune up has ever been done on this car.
Wheels and tires are okay.
Jan 31, 2018 at 8:01 PM
STEVE W.
  • 15,113 POSTS
What was the light reset for? Was the issue that caused it repaired or just the light reset?
The description could be almost anything from a bad CV joint to engine misfires to transmission or bad brakes.
When it starts do you feel it more in the steering wheel or the seat? Does it change if you let off the gas or lightly ride the brake? How about when you steer, does it get louder turning one way over the other? If you turn fully left and fully right at low speed in a parking lot is there any noise like clicking or popping?
Jan 31, 2018 at 9:49 PM
SSSUSANNN
Because it could be a number of things, the biggest problem seems to be with acceleration, driving roughly/vibrating/humming for about ten minutes, and then okay until the next acceleration. Nothing noted with turning, clicking, popping. I feel it in the gas pedal and steering wheel. And possibly some faint smell of burning. The reset might have been needed because I topped off with the car running, although in the last few months if I have reset it three times, cannot remember if the car was running when I topped off. 145,000 and no known tune up, wondering about the fuel injectors or fuel filter/spark plugs/wires/coil? Less of a problem at slower speeds or idling.
Feb 1, 2018 at 8:40 AM
STEVE W.
  • 15,113 POSTS
It sounds like you need to have it scanned to see what the codes were and if there are any hidden codes. Then possibly do a full tune up. Resetting the light does not repair the problem. If you can post the code(s) we might have a starting point.
Feb 1, 2018 at 9:23 AM
STEVE W.
  • 15,113 POSTS
Have you had any changes or updates with your vehicle problems?
Feb 8, 2018 at 5:34 PM
