Car sometimes doesn’t start. When it doesn’t it doesn’t turnover at all but all accessories work. You do hear a click, but it does not turn over. Battery is new less than year ago and volts check good. Checked all fuses specifically F3 and F11 and they look good with no evidence of burn through or arcing that may be intermittent. Swapped some start relays and didn’t fix. I have applied power directly to the output side of the T20 ECM start relay and have started it that way but doesn’t always start bypassing the relays. Does this mean it’s more than likely the starter? Being that I’m going directly from the battery 12 v to the starter, and not only does it not start it doesn’t turnover. I would think putting juice to it directly should at least turn it over.
I’ve also swapped other relays into the T20 ECM starter position, T14 BCM Start and the T09 Run start relays on which none of them made a difference. Jump starting doesn’t help either just for reference. Nothing really works except just trying to start with the key. Sometimes 15-20 times or let it sit for an hour or two and then it might start up. Again, I have started it several times with direct power from the car battery to output side of the T20 ECM start relay. But just like turning the key it just clicks and then eventually you do it and it starts so I think it’s same scenario as the key as whatever is not working just intermittently decides to work. But with that said like mentioned earlier if I put power directly to the starter it still doesn’t turnover or anything it just either clicks or starts fully. I’m pretty confident it is the starter but it’s also the most expensive and time-consuming fix. Just looking for a second opinion. I mean there’s an outside chance that it’s ignition switch or related, but the car doesn’t start with the remote start either. And I suppose a remote possibility could be shift neutral switch or something too. Anyway, looking for a second opinion. Thoughts?
PS - Oh and I almost forgot about a month ago or so I cleaned all the frame grounds from battery and engine as they did have decent corrosion, and car ran without issue for about 3-4 weeks. So, I thought I had it licked but then it just started back up again. So, I did initially look at the grounds for what it is worth.
Dec 19, 2024 at 10:57 AM
