Okay, yes I understand.so I rewire one of the injectors back to the computer and yes if the code comes back. If the code does not come back after rewiring then I prove that the shirt is in the wiring harness. In which case I would probably remove the harness and open it up to discover wire the the wires are shorting to each other or to ground? Correct???
With the included pictures you probably has figured that I am Elizabeth. I am David, Beth’s husband, she set up the account on an issue a while back and you helped us. So we just use her account.
Attached pictures and questions. I see on the diagram color coding. Can you tell me or point out on the diagram which cylinder is number one and which is four. Is it front to back or back to front.? Also there are a series of connectors that are close to the computer box. Did the injector wires run to these connectors and then to the box or to the end of the actor wires run directly to the computer? I’ve been clued it included a picture of the connectors in the computer module box I am assuming that all the wires from the harness run to these connectors and then connect to the computer module.? Also, I see the injectors, where is the turbo chargers or charger?
Sep 6, 2020 at 8:42 AM
