Intermittent stalling, erratic idling?
1998 NISSAN CEFIRO
200,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ED SANCHEZ2
Hi. Just wanted to ask if you've encountered this problem with the car listed above A32 with the 3.0L VQ30DE V6 engine.
- Intermittently, idling drops then car stalls, but usually only while stopped, not while running.
- While running at low speed, engine starts misfiring (?) - sputters, revs jump up and down, and stepping on gas does not produce revs, so pull over and wait it out, or restart if it stalls
- Cleaned the fuel tank
- Cleaned the MAF and the IAC
- Still happening
Any suggestions? Thanks!
Apr 16, 2023 at 8:29 PM
I would do a full tune up. This guide can help walk you through the steps, also I would service the throttle body and check for vacuum leaks.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Use this guide when the engine is cold only:
This guide may help as well:
https://www.2carpros.com/articles/stall-at-idle
We should run the codes as well.
Please go over these guides and report back.
Apr 17, 2023 at 12:23 PM
